Please help.
Chop78
12 REPLIES 12
Waddizzle
Disconnect any lens that you may have mounted.  Reformat the card in the camera.
Try resetting the camera, too.  Check the manual, because this must be done in at least two places in the menus.
Thank you. I did reset all camera setting and custom functions, also format the card that camera works with. Camera did not recognize other cards so i couldn't  format them by camera. I checkec the card slot and everything looked exactly like the other t3i I got. I wonder if card reader is broken, but I have no idea about the sensor cleaning issue.
Are you saying that you have two T3i's? If so, try formatting a card on the "good" camera and see if the "bad" camera can read it.
However, it does appear at first glance that the camera's problems go deeper than a bad card. If that's the case, it may need service. And then you have to determine whether it's really worth saving.
Bob
Thanks Bob. I followed your advice and still have problem.
I do not think of sending it in for service, the cost possibly exceeds the value of an used T3i.
You need to call Canon support to set up a service.  Your camera is faulty and needs repair.
ScottyP
Sorry you are having problems. If this is a repair that exceeds the logical limit to spend on an old. Key look at the newest Rebel T6i and T6s. Really big improvement over T5i.  If you are not in a hurry the T6i/T6s price should come down in 6 months as the refresh cycle churns on and we see their replacement T7-something come out.
Scott
It doesn't sound good.  But, I have questions about the card(s).  What memory size is the card that works?  The card(s) that don't work?
Are you using full size cards, or micro-SD cards with adapters?  Adapters tend to fail quite easily, probably because they warm up and the plastic cases expand, and then contract when cooling.  Over time the connections with the camera will be compromised..  Only use micro-SD cards in devices that use them directly.
Hi Waddizzle. The card that works is 16gb sandisk extreme pro. Others that do not work are also 16 gb, 32gb, sandisk ultra and 64gb lexas professional. Do you think I should try to replace the card reader first to see if problem go away? Or should i just sell it for part? im ok with disassembly
You've lost me.  Are you using a separate card reader?  Should you "sell it", meaning the malfunctioning camera?  I might keep the camera around for spare parts, especially if I had another functioning camera just like it.  I do not recommend to anyone to attempt repairs themselves, though.
The 16GB and 32GB cards are the right type for your camera.   The 64GB card is supposed to be compatible, too.  You have made no mention of getting card error messages in the viewfinder, I have noticed.  It sounds like your camera has experienced a hardware failure.
Holiday
