01-08-2021 02:30 PM - last edited on 08-25-2022 10:29 AM by Danny
I have been taking a lot of photos lately. I use the plug-in for the USB port to download from the memory card. When I go to review the photos, I find that each photo has a copy designated as XXXX (1). I hate to take the time to delete each one as unneeded. Is there something in the camera or laptop computer that is doing this? TIA.
01-08-2021 02:46 PM
Are they both the same date?
If the camera has been used a while and you are downloading to the same folder you may have "rolled over" the file counter. The camera will only go to 9999 and then it starts over, so 0001 and 0001(1) could be 9999 images apart.
01-08-2021 02:55 PM - edited 01-08-2021 02:57 PM
Camera is fairly new. Photos are numbering in the 65XX. I'll check the items you mention. Thanks for the prompt reply.
Was in Waterville Valley, NH, several years ago. Beautiful area. Saw moose crossings but never saw one.
Edit- photos were taken at the same time.
01-08-2021 03:03 PM
01-08-2021 04:12 PM
I'll try but I'm not a computer whiz. Might take a bit of experimenting. Again, thanks.
BTW, you are the first person to answer a question on the Community.
01-08-2021 04:19 PM
This is a computer problem. You need to remove images from the camera after you are sure they are safely imported. After I verify that all the images imported, I re-format the card in the camera.
01-08-2021 04:33 PM
I do that. I'm a freelance writer and photographer. I tend to take multiple shots of the same subject. I don't like to have bunches of photos on the camera. As I mentioned, I get two copies of the same photo. I try to select the ones not already downloaded. Usually all photos are new. I'll see if I can come up with the file as you noted. Thanks!
01-08-2021 04:34 PM
Noticed you re-format the card! That might be the problem. Again...many thanks.
01-08-2021 06:06 PM
Yes, if you do not delete the files after you download some programs will "allow" you to download the same files over again. I missed that possibility since Lightroom or Apple Image Capture will ignore suspected duplicates/previously downloaded images. You can either reformat the card or simply erase all images after you download.
01-08-2021 08:42 PM
2 copies of the same photo might be one as a jpg & the other a raw file (CR2 extension)
