Opteka EF-M Lens on an EOS Rebel SL3
morgansimoneca
Hi! I have a Canon EOS Rebel SL3, and I recently recieved an Opteka 35mm lens for Canon EF-M.
Is there an adapter that I could use with the lens so that it works with my camera? It doesn't fit normally but I still wanted to use it.
rs-eos
No; no adapter exists (nor is it possible) to mount an EF-M lens onto your EF-S mount body.
See Will Lens X Work on Camera Y for details about what is possible.
Ricky
6 REPLIES 6
Waddizzle
Negative.
rs-eos
Ricky
deebatman316
EF-M lenses CAN NOT be adapted to DSLR cameras. However DSLR lenses can be adapted to EOS-M/ EF-M mount cameras.
-Demetrius
Happy New Year
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired), EF 50 F/1.8 STM, EF 85mm F/1.8 USM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired) & 5D Mark IV
430EX III-RT, 470EX-AI & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Ditto what the others have said.  If you want to understand why, here's an article that might help: https://moonblink.info/MudLake/gear/lenses
ebiggs1
One lucky thing is, if it's like other Opteka lenses, it a good thing you can't use it. There is a reason it is a fraction of the cost of the Canon EF 35mm f/2 IS USM Lens.
EOS 1DX and many lenses.
Okay! Based on your link, I found a Yongnuo YN 35mm f/2 lens for Canon EF so that should work for my camera then!
