07-11-2020 01:10 AM
Hey all! Just got my new M50 and everything was great today. The only thing is, I did some very light playing around, trying out the different modes, very minimal setting adjustment (things like preview timer), etc., and somehow my memory/shots available has seemingly permanently dropped by ~15%. I have no idea how or what I might have done.
(I'm using a 64 GB SanDisk Extreme PRO SDXC UHS-I card.)
When I started, I had ~6800 shots available at the default image setting, which as far as I can tell is Large, no RAW, 6000x3000 or whatever the res is.
I took a few different shots and 1 short movie, maybe 100 items in total, and when I looked again (after deleting the movie) I had 5800 available. I looked through all the settings and couldn't tell what I might have changed. I then tried everything- deleting all the shots, resetting the camera's settings, deep formatting the mem card, and no matter what I did, I still had 5800 shots.
How on Earth did I lose the capacity for 1000 shots?
The memory available on the card is the same as when I started- 854kB of 59.something GB.
I'm guessing it's something I set but I have no clue at this point.
Your help is much appreciated! Thanks!
07-11-2020 05:38 AM
You haven't lost anything. the number of available shots is a rough estimate because the amount of memory an image uses varies with image contents. Probably the camera has made a more realistic estimate.
Anyway,are you really likely to take more than 5800 shots before you download the contents of the memory card.
07-11-2020 11:14 AM
@bigbrother,
Ray-UK has givien excellent advice. I agree with him regarding use. I back up my photos after each day of shooting. Having 2 sets is safer than one.
07-11-2020 11:19 AM
Actually the determining factor is ISO. Change it from 100 to the higher numbers and watch the number of shots go down.
07-11-2020 05:53 PM
That was it! (Was actually recommended on another forum and just tried it.)
For some reason Auto ISO increases the estimated memory size of shots.
07-11-2020 06:21 PM
@bigbrother wrote:That was it! (Was actually recommended on another forum and just tried it.)
No, it doesn't. It is just a happy coincidence.
07-11-2020 08:30 PM
Because it assumes that the highest value you have set is the worst case.
Waddizzle, I am not sure what your point was. ISO is the determining factor for the estimated image size. Go ahead and try yourself.
07-12-2020 03:53 AM
@kvbarkley wrote:Because it assumes that the highest value you have set is the worst case.
??? ISO Auto didn't fix anything.
My point was simple. Setting ISO to Auto was a coincidence. Yes, it raised the ISO value. But, using ISO Auto could have just as easily lowered lowered the ISO value. Setting ISO to Auto did not "fix" anything.
07-12-2020 02:04 PM
07-12-2020 03:31 PM
Guys, do the experiment yourself. Watch the image count as you change the ISO, it clearly adjusts in an inverse relationship.
