New EOS R50 V User Confused about 4-channel audio options
mikefulton
I am such a new user I don't even have my camera yet
I'm sitting here waiting for the Amazon driver to deliver it.  I did get my memory card already, though.
When recording video, the camera has the option for either 2-channel or 4-channel audio.   If I understand the information I've read correctly, when recording 4-channel, you can have:
  • 2 channels from built-in microphone (is this mono or stereo?)
    or:
  • 2 channels from the multi-function shoe
    Plus:
    2 channels from the "mic" input
Am I understanding this correctly, or is there an option to get all 4 channels from the multi-function shoe?  I've been searching for accessories online and it seems like the only intersection of "audio" and the multi-function show is a shoe -mounted microphone like Canon's?
What I'd REALLY like to get for audio is an external multi-track recorder.  Is anybody doing anything like that? I'd love to hear about your setup.
The internal mics on the R50v are stereo 🤗
In addition, you can use a 3.5mm stereo mic or multifunction shoe accessory microphone like the DM-E100 for a total of 4 channels.  The gain on each channel can be adjusted independently in camera. The gain or balance between the inputs (onboard vs. accessory)  is not adjustable in camera 😉  Hope this clarifies things.
7 REPLIES 7
@shadowsports wrote:
Are you sure this is the case? I can't manage to combine the internal stereo mics with the 3.5mm input. If I plug in an external microphone, the camera simply mirrors those two tracks to channels 3 and 4 when recording in 4 channels (which is just useless waste of storage). I can't find a way to enable the internal mic as long as an external one is connected via the 3.5mm input.
As far as I can tell, the only way to actually get 4 channel audio is by combining a hot shoe accessory for audio and either the internal and an external mic. And the only two devices I've found to support the hot shoe are the Canon DM-E1D which costs about half as much as the body itself or the Tascam XLR adapter which costs about as much as the body itself.
You have to enable lpcm 24-bit/4-channel. See the audio format heading in the link below.
Canon : Product Manual : EOS R50 V : Sound Recording https://share.google/A3PGOWWIynfqWPFtF
The microphone you're plugging into the 3.5 mm jack has to be a stereo mic.  Your playback software also has to support 4 channel audio.
Hi Rick, thanks for the response. 4 channel LPCM is selected, but no matter what I do I can only get internal mic on channel 1 through 4 or external mic on 1 through 4. Channels 1 and 3 and 2 and 4 always contain the exact same audio. I don't see any way to change the sources for either channel and the manual also does not explain how this could be configured.
Petruchio
Exactly the same story.
4-channel recording. Monitoring 3-4 channels.
Result: 4 identical files. 2-4 are out of phase.
I connected a Zoom F3, a Sony stereo microphone, and a lavalier radio.
If I don't connect anything in 4-channel mode, it also records 4 identical files.
I think it's a firmware bug. What do you think, Canon?
It can't record 2=2 independent stereo channels.
This is visible on the camera's screen. It switches the names of all four inputs to EXT and INT.
As far as I can tell, the only way to actually record 4 channel audio is to use an external microphone via the multi-function shoe (which at this time means either the mediocre at best DM-E1D or the Tascam CA-XLR2d-C, which is really cool but also costs about as much as the R50Vs body...).
I think it's really disingenuous to leave the marked reply to this up as it's clearly very misleading.
Maybe someone from #CANON can shed some light on these 4 channels ((((
