12-08-2016 05:59 AM
Have the Mark III - May get the 5DSR - Has anyone used the 5DSR with Neutral Density Filters 6,10,15 etc.. and what have been the timing lengths used- and outcomes?
Any noise issues? Other problems noted?
12-08-2016 09:15 AM
@hpk wrote:Have the Mark III - May get the 5DSR - Has anyone used the 5DSR with Neutral Density Filters 6,10,15 etc.. and what have been the timing lengths used- and outcomes?
Not really an answer to your question, but since the 5DsR is a very high-resolution camera, you can expect to need a very high-quality filter in order to obtain the best results.
12-08-2016 09:39 AM - edited 12-08-2016 10:32 AM
I haven't used tat combo either but I am curious to know why you think it would cause any problems? Surely not any more so than the Mk III.
12-08-2016 09:48 AM
@ebiggs1 wrote:I haven't used tat combo either but I am crious to know why you thnk it woulod cause any problems? Surely not any more so than the Mk III.
I have little doubt that, as B from B noted, that the camera will mercilessly capture any flaws in the ND filter, or any filter for that matter.
12-08-2016 10:39 AM - edited 12-08-2016 11:27 AM
Well it goes without saying, you want the best of everything you can get but I see no real reason the Mk IV EOS 5DS R will exhibit any problems. We must assume the OP will buy top quality accessories for a Mk IV EOS 5DS R. It makes little sense to buy a Mk IV EOS 5DS R and use junk with it! I haven't used the Mk IV EOS 5DS R as admitted but I have used a 36mp camera (some claim a better sensor than the Mk IV EOS 5DS R) and there is no issue with ND filters.
Edited post!
12-08-2016 10:50 AM
@ebiggs1 wrote:Well it goes without saying, you want the best of everything you can get but I see no real reason the Mk IV will exhibit any problems. We must assume the OP will buy top quality accessories for a Mk IV. It makes little sense to buy a Mk IV and use junk with it! I haven't used the Mk IV as admitted but I have used a 36mp camera (some claim a better sensor than the Mk IV) and there is no issue with ND filters.
Er ... When did the discussion shift from the 5DsR to the Mk IV?
12-08-2016 11:22 AM - edited 12-08-2016 11:26 AM
Oh for Pete's sake, see edited post!
12-08-2016 04:03 PM - edited 12-08-2016 04:10 PM
Thank you for your thoughts all. I had read form some post that because of the camera ability to capture high pixels that it would show more issues / noise--- Thats why I posted here to see if anyone has tried such. just a question but your right why would it over the other cameras!
Yes, quality filters a must,
I heard from G Dan Mitchell, - Dan Mitchell photography - he has used such combos and as we suspected no more then other 5d versions from the sensor. Good to know!
12-08-2016 10:03 PM
12-20-2016 12:18 AM
I use a 15 stop lee super stopper. I have taken longer exposures than 7 minutes at iso 100 and the noise is easily removed in photoshop. It's not a sony, but it works well, I think.
