07-31-2022 07:35 AM
-Direct acces to minimum shutter speed with AutoISO ( or a Safety Shift in M and AutoISO, basically the same).There are four ( !) dials….
-To speed up manual, when using *h ( exposure lock hold) in M, and changing aperture , shutterspeed should change to obtain exposure.
-Tracking should be possible in ALL AF modes.
-Direct switching to full electronic shutter, don't want to switch off anti-flicker first, I know anti-flicker doesn't work in electronic.
-Switch off sensor and close shutter when detaching a lens, instead of turning camera off, change lens, turn camera on again....
-Electronic shutter sound optional.
-Electronic shutter in 10fps optional
-Spotmetering linked to focus point.
-Flash-photography: possibility to influence brightness/exposure of EVF in Exposure Simulation Off Mode( you might be looking at a silhouette when photographing a person in front of a window, and exposing for light outside)
-Customizable Quick Menu.
-Function for the Rate Button
-Possibility to move focus point when shutter is half-pressed
-When using *h, AE lock hold, you can't at the same time lock exposure with the shutterbutton.
Just to add : I have been working with Canon professionally for 25 years, and switched to Sony 4 years ago ( A9 and A9II) , moved back to Canon with the R5, and would have been totally happy if I came straight from EOS 5 IV. But Sony had a few good things that I miss now, like working with Auto ISO, which is, when you really think about it, the first and only variable you want to have in an automatic mode.And yes, I work in full manual most of the time, but sometimes you just need the speed of A, or you want to concentrate more on the people or the surroundings then your camera.
07-31-2022 01:36 PM - edited 07-31-2022 02:52 PM
@paulamsterdam wrote:Ofcourse a faster shutterspeed! But I want the camera to do that automatically, raise the speed to 8000 . If you were inside at 125/f2.8( and AutoISO) and suddenly you have to run outside , something happens there, then you have to remember to raise your shutterspeed. That's called "Safety Shift" It's there for A,T and P, but not for M (icm with AutoISO) If you don't get it, don't use it. But it would make me very happy 🙂
Not to sound condescending, but do you fully understand how a camera works?
There is a very simple reason why “Safety Shift” is not available in M shooting mode. It is because you are manually setting the exposure. The camera is not controlling shutter or aperture. You are.
This means the camera is [NOT] able to control shutter or aperture because you are controlling them. This is how it works. If you wish to make use of Safety Shift, then use another shooting mode. Safety Shift is not unavailable in M shooting modes.
07-31-2022 01:39 PM
@Waddizzle wrote:“-I want SPOT(!)metering linked to the AF point. Not Evaluative( which indeed does take into account which AF point you are using)”
Spot Metering is linked to the Spot AF point. If you wish to have metering linked to any AF point, then use Evaluative Metering. It is crucial that the AF point be active when the metering is locked [when the shutter fired] for metering to be evaluative at the locked AF point.
But I WANT spot metering all over the sensor, not just in the middle.Movable. Evaluative metering is something completely different
“-When you set "Shutter button half press to AE lock" ( customize button menu) you won't be able to use/set "*h button" ( lock hold, holds AE, just press, and press again to release), which I love. Try it. Like working in M, but much faster.”
Exactly. One-Shot AF behaves that way by default. Exposure is locked when focus is locked just before the shutter is fired. Servo AF behaves the same way. It constantly refocuses, but it locks exposure when the shutter is fired. You have overridden the button. So, what is the problem? I do not see what your complaint is all about.”
My complaint is that *h ( AE lock hold) doesn't work in conjunction with AE lock shutter button. I use BBF by the way, Servo or One Shot ( who still uses that?) has nothing to do with it
“-Flash photography : try to make a portrait inside in front of a window, looking out , and you want to expose for the sunlit skyline outside, let's say 125/f8/ 100ISO. You will be looking at a silhouette, with or without Exposure Simulation enabled. That's when I want to be able to adjust the exposure in the EVF( or use SPOT metering linked to AF point) . Brightness EVF just won't cut it.?”
This scenario is best handled with off camera strobes and a light meter. You cannot visually simulate the exposure without firing the strobes. You can only measure it. If you wish to actually see it, then use off camera lighting.
Of course I'm talking about off camera flash, and ambient and flash are all set manually. My problem is not getting the right exposure, my problem is I can't see the expression in the face during the shoot. And that is what portraiture is all about. Yeah, I can take a picture, review etc, that's not really a nice way of working. That's where I miss a DSLR , because you're eyes easily overcome that contrast. But even the Optical Viewfinder Simulation in the R3 can't.
07-31-2022 01:41 PM
Do you understand how AutoISO works?
07-31-2022 01:58 PM - edited 07-31-2022 02:04 PM
@paulamsterdam wrote:Do you understand how AutoISO works?
[EDIT] ISO Auto means the camera is controlling ISO, not shutter speed.
Good luck with finding solutions for your work flow. I’m out.
