My canon eos 80 flash screw has rust and i need a replasement
needhelp1_80D
I was taking photos on the beach when a big wave struck a rock and sal water soaked me and all my camera gear, luckily nothing got damaged, after I came home I cleaned my camera with alcohol, I didn't think water got into the flash, so I didn't clean on there, but it did and rusted one of the screws... i need a replacement screw, but can't find one anywhere.IMG_0095.jpgIMG_0096.jpg
Recommendation to clean and paint is best. However, if you really want to get a Canon replacement screw you can go to uscamera.com and download a PDF of the parts manual. It will have the part number that you can then order from Canon.
9 REPLIES 9
rs-eos
Since the EOS 80D isn't weather sealed, there is risk that other elements of the camera have also become damaged; especially so with salt water.  I would recommend scheduling a service to have Canon give it a complete checkup.
Ricky
normadel
Does the flash function? Does everything else about the camera work okay? If the screw appearance is your only problem, just clean it and be happy.
jaewoosong
Rising Star
Rising Star
you can clean the screw soaking in coke for a few min and brushing with old toothbrush.  I clean bike parts that way that has rusted.
-jaewoo
Rebel XT, 7D, 5Dm3, 5DmIV (current), EOS R, EOS R5 (current), R50V (current)
yeah the flash works great, and I use an external flash so I'm not really going to use the internal flash that much, but still i with every thing on my camera to be perfect
sry i can't afford it, and i check every thing and it works like new, only that one screw got rust
if only I could have the part number of that screw ill be happy
You ruined your wish to be perfect when you let it get soaked in salt water.
Clean the screw and repaint it.
thanks ill do that
