11-13-2016 01:49 AM
I have a canon 70D and i left it for 4 months without using...now when i tried to turn it on...the screen showing white screen with vertical black lines...it is not an LCD defect, because all the functions and menu can be accessed clearily...also the screen give a warning Exp.SIM ...it might be trivial things to you guys but i am new with this field.
looking for help please.
11-13-2016 02:30 PM
11-13-2016 02:43 PM
Looks like it needs to go to Canon service center. Something is wrong insdie camera.
02-20-2017 05:18 AM
Hello,
I would like to know the feedback of this suggestion because my 70D is doing the same thing.
My 70D started displaying white with verticle lines when previewing images, also in video mode the screen was having glitering (stucking and refresh rate was very slow).
Later on the pictures all together was not captured by the card even if I use the OVF to take photos, they also have the same white with colored verticle lines.
04-08-2017 12:27 PM
Hi, did you fix your camera afterall?
Did you send it to the service? If so, what was the problem and how much did it cost to fix it?
I'm having the exactly same problem with my 70D
Thanks
04-08-2017 02:30 PM
If you click on milanguy's name you will get a page where you can select to send him a private message.
Contacting him diectly may get you a better response.
04-09-2017 08:32 AM - edited 04-09-2017 08:33 AM
@jrhoffman75 wrote:If you click on milanguy's name you will get a page where you can select to send him a private message.
Contacting him directly may get you a better response.
Except that the icon that says you have a private message is so inconspicuous that it's easy to overlook it.
04-09-2017 08:56 AM
But I always get an email that says I have a Private Message.
07-10-2017 02:55 AM
