12-10-2023 01:33 AM
A few years ago, I bought DSLR EOS Rebel T6 camera. It was working well. Suddenly, two weeks ago, it stopped responding. I have changed batteries by buying new one from Canon also.
I am visiting Katy, Texas from India and would like to get it sorted out as early as possible.
12-10-2023 02:01 AM
What exactly does “stopped working” mean”?
Will it take photos? Does it still turn on?
What brand and capacity memory card are you using? If yo remove the memory card and lens does it turn on?
12-11-2023 11:25 AM
Will it take photos?: No
Does it still turn on?: It turns on, but no operation
What brand and capacity memory card are you using? If yo remove the memory card and lens does it turn on?: SanDisk Extreme.
12-11-2023 11:50 AM
You did not mention damage that may have occurred like getting it wet even a little wet or dropping it even a little drop. Remove the lens and SD card and try it. Also remove any off brand accessory like a battery grip and try it.
If it doesn't work there is little else you can do.
