10-18-2015 06:39 PM
My only recourse is to remove the external battery. Please advise.
10-18-2015 08:24 PM
@kellyswanson wrote:My only recourse is to remove the external battery. Please advise.
"External battery"? Let me guess: It's in a 3rd-party battery grip?
10-18-2015 08:45 PM
10-19-2015 02:02 PM
10-19-2015 02:24 PM - edited 10-19-2015 02:40 PM
Power on/off switch problem ?? Send it to Canon service center if resetting to factory default won't work.
Check out other discussions regarding similar problem of the othe brand camera.
http://www.dpreview.com/forums/thread/2889465
Good luck.
10-19-2015 06:41 PM
The switch is a "soft" switch in that it mere tells the camera you want to turn it off, but does not cut power. (Normally the camera will invoke a sensor cleaning cycle it powers off.)
This may be a loose connection inside the camera, but you would need to send the camera in for service. There won't be any reset option to correct it.
