09-16-2015 01:31 AM
So when i take pictures wit hmy 60d, alot of time the whites area when reviewing it on the camera would be flashing. And this is bugging me, i wondering if this is able be prevent.
09-16-2015 08:01 AM - edited 09-16-2015 08:03 AM
09-16-2015 02:05 AM
09-16-2015 09:17 AM
Two things to add the the very good previous post.
One along with highlights you can display RGB. Both can be turned off in the menu.
And number two don't install Magic Lantern. Almost no good will come from that. Canon does not approve of it in any way shapre or form.
08-20-2022 02:11 PM
I've got the same problem. Responses say to correct the problem in the Menu. Just what in the menu am I looking for and where in the menu should I start?
THANKS - PS: I will not install Magic Lantern. Always learn something here.
08-20-2022 02:28 PM
You really should start a new thread of your own. Be sure to state what camera you are using so that someone can tell you what to do.
08-20-2022 02:46 PM
Thanks. I'll do that.
