10-30-2024
06:03 AM
08:45 AM
hi there!
i noticed that my canon Canon Eos250D buttons stopped working. the button that you use to take a picture still works but the menu, function, set, and display buttons don’t work when pressed. if anyone has any solutions, i’d be so grateful to hear them!
10-30-2024 08:27 AM
Do you have a lock switch that might be engaged? Here is mine on the T6S:
10-30-2024 10:10 AM
No I don't.
10-30-2024 10:27 AM
Does the "Q" quickset button work? i.e., can you use the touchscreen?
10-30-2024 11:57 AM
No it's not working. But at some point, everything comes back to normal, then when I take one or two pictures, it goes back to the same problem.
10-30-2024 12:12 PM
All I can suggest is that you reset the camera at the time the buttons are working.
10-30-2024 02:25 PM
I assume that since you have a 250D rather than a Rebel SL3, that you are not in the USA, but if you are then call 1-800-OK-CANON to talk to tech support. Otherwise, I would suggest you call your local Canon support - this should be in your manual at the back or your local Canon authorized dealer may be able to give you the contact details.
