Movie Size Quick Control and High Frame Rate on the R7
ronzigler
It appears when you enable High Frame Rate on the R7, it prevents you from changing the size of the movie through the Quick Control access. This is my experience so far. I need to go to the main Main Menu and disable High Frame Rate before I can make changes in the frame rate thought the Quick Control option. Is there any way to set up a quick control short cut in order to enable or disable the High Frame Rate option without having to go to the Main Menu?
0 REPLIES 0
