04-05-2023 02:52 PM
Hello experts. I just bought a refurbished M6 Mark II directly from us.canon.com . Everything works really well but I noticed that I'm not able to record any audio using an external microphone (internal mic works fine). I'm using a Rode SmartLav+ lavalier mic.
Few questions:
1. Does Canon test the mic input in its refurbishing process?
2. Any known issues with using a TRRS 3.5mm input from a lavalier mic? The same mic works fine on a laptop, for example.
I'm really hoping not having to return this awesome camera ! 😞
Thank you for responses
NND
04-07-2023 06:09 PM - edited 04-07-2023 06:09 PM
Capturing the resolution here if it's helpful for others in the future.
Using a TRRS to TRS converter helped resolve the mic issue. The Rode SmartLav+ microphone has a 3.5mm TRRS pin, whereas the input jack in the camera is TRS.
04-05-2023 03:07 PM
Hi, NND! Canon factory refurbished cameras are all covered by a 1-year warranty and if it's soon enough, you might even qualify for our 14-day return and exchange policy. If you're unable to find a solution here on the Canon Community Forum, you're welcome to call our EOS support team at 1-800-OK-CANON (1-800-652-2666) or, if applicable, our sales team at 1-800-385-2155. Both are open weekdays and Saturdays.
Hope this helps!
04-05-2023 05:23 PM
Thank you for your quick response. Do you happen to know if the mic input is tested as part of the refurbishing process?
In the meantime I've ordered a TRRS to TRS adapter to see if it's a compatibility issue between my mic output pin and the microphone input jack.
