11-07-2018 04:05 PM
Hi guys.
I am looking to upgrade my memory card for my Canon 600D. I have been contemplating getting a 200GB micro SD XC card that comes with an SD adapter. Will these be functionable in the camera and work OK.
Cheers in advance guys
11-07-2018 04:32 PM
No. Do not use a microcard with an adapter. They have been found unreliable.
11-07-2018 05:13 PM
No worries. Thanks for the advice.
11-10-2018 09:34 AM
Super large SD cards are also a bad idea.
11-10-2018 01:37 PM
kvbarkley and Ernie are giving you good advice. Get an actual "SD" card ... not a "microSD" card with adapter. There have been loads of "how come my camera isn't working right" posts here and the end result was the adapter wasn't really working. Photographer gets the correct SD card (normal SD card size) and all is right again.
Also, a few smaller cards is better than one really big card. You'll find that even in a 32GB card size, it takes a LOT of shooting to fill that card (and I shoot RAW ... so the files are big). But just occasionally a card can fail. It's a better idea to have a few cards so you have a spare card and may not all of you photos are on the failed card.
Another reason I believe in spares is due to my sometimes forgetful memory. I insert the card into a card reader on the computer to unload it. Then I *forget* to put the card back in the camera. You don't want to be two hours from home, power up the camera and see "no card" displayed ... and not have a spare card in your camera bag.
11-10-2018 01:50 PM
11-10-2018 05:30 PM
@PeteWill wrote:
All sound advice from everyone. Thank you all. Not having storage size issues, I was just thinking of getting a large GB size one for, well, basically the hell of it but will look at a few smaller sized SD ones now. They’re not too badly priced either to be fair.
Once again, thank you all.
Most large capacity SD cards probably would not work very well in the your camera, anyway.
Make sure that you only buy a “UHS-1”, not “UHS-II”. Most of the 128GB and larger cards are “UHS-II”, which is not completely compatible with your nearly all Canon DSLRs.
I like the Sandisk Extreme and Sandisk Extreme Pro UHS-I 32/64 GB cards. I use the 32 GB in my Rebel T5 and EOS M5. I use 64 GB in more expensive cameras.
11-11-2018 10:39 AM
"...basically the hell of it but will look at a few smaller sized SD ones now."
I know some folks, mostly Moms, that think the camera is where you store all your pictures, too. They never delete anything! But then again it is that iphone mentality. They try to make the camera work like their cell phones do. Listening, yet, Canon?
11-11-2018 12:34 PM
11-11-2018 12:47 PM
No presumption on my part at all. Just an observation. There isn't any good reason to have a huge card unless you intend on storing a huge amount of photos on it. That's all nothing more. My suggestion of several smaller SD cards is to help protect you in the case a huge card failed. In reality SD card failures are pretty rare but in my case I can not take even that small chance.
