Mark on All My Pictures Regardless of Lens
barbere
Hello! I'm hoping someone can help me figure out what's wrong with my Canon Rebel T5. I know it's an older model, and I got it used a few years ago. I've gotten decent use out of it, around 5,000 shots, and I've treated it gently (never dropped it or anything) but recently I've had this mark on my pictures and I have no idea why. It's driving me crazy. When I look through the viewfinder, it looks normal, but when I take the picture, every image has this hairline crack mark on the right side. That's how it comes up on the LCD screen and how they download as well. Depending on the settings I use, sometimes it will be more pronounced or blurred. Initially, I thought it might be the lens, but the lens looked perfectly fine. I switched lenses and the mark was still there, so I know it's something to do with the camera body. I looked at it and I can't see anything abnormal, so maybe it's something inside?
At this point, I'm not sure if it's worth it to repair it or if I should just get a new camera, but if someone has any idea what caused that, I would appreciate it. I'll attach images I took with different lenses so you can see what it looks like. Thank you!
Lens 1:
Lens 2:
4 REPLIES 4
kvbarkley
VIP
VIP
Hair on the sensor. You can get a rocket blower and try to remove it. Should be good as new.
You can also send it to Canon for a cleaning.
(If not for Covid, I would say to go to Albuquerque during Balloon Fiesta and Canon will do it for free, while you wait. Alas, Covid has led to the cancellation of the Fiesta. No cleaning for me this year!)
ebiggs1
It does look like a hair on the sensor or some such anyway.  But a Rocket blower won't help unless you can lock the mirror out of the way as the mirror blocks access to the sensor.  BTW, there is also a shutter in the way, too. It also has to be moved out of the way.
A Rocket blower is more of a lens cleaning tool than a sensor cleaning tool or perhpas just a quick blow out of the mirror box area.
The camera has a function to facilitate cleaning. In this case it would be best to actually hold the camera upside down so the hiar falls down out of the camera.
This means use a Rocket Blower air bulb.  I do not recommend that you try to use a sensor cleaning swab kit to do it.  If the blower does not clear it off, which it should, then you should contact Canon Support.
Avatar
