06-28-2024 04:07 PM
Wondering if anyone has experienced a problem with the main dial (by the shutter button) on their 5D IV. I have to really lean it forward while turning it to get any result. Just rotating it makes nothing happen. Anyone else have this issue? Thank you.
06-28-2024 06:11 PM
Does the 5D Mk IV have a rubber "tire" around the wheel? If it does, the tire could be slipping on the wheel. I had this problem on a 50D and saved it from the scrap heap
If the answer is "Yes", I'll share a simple no-cost fix with you.
06-28-2024 06:24 PM
Thanks for taking a look, unfortunately it is a toothed wheel - no rubber.
