Main dial on EOS 5D IV not working reliably
henrywjohnson
Wondering if anyone has experienced a problem with the main dial (by the shutter button) on their 5D IV.  I have to really lean it forward while turning it to get any result.  Just rotating it makes nothing happen.  Anyone else have this issue?  Thank you.
2 REPLIES 2
normadel
Does the 5D Mk IV have a rubber "tire" around the wheel?  If it does, the tire could be slipping on the wheel.  I had this problem on a 50D and saved it from the scrap heap
If the answer is "Yes", I'll share a simple no-cost fix with you.
Thanks for taking a look, unfortunately it is a toothed wheel - no rubber.
