06-12-2022 12:29 AM
M6 electronic level doesn't show in the viewfinder. I have the EVF-DC1. It shows up in the M3, so this seems weird that it won't in the more advanced camera. Is this a normal thing or a bug in my camera?
06-12-2022 01:53 PM
I just found the VF display settings which solves the problem, though I feel a fool for missing it
06-12-2022 10:21 AM
If you using the “EVF-DC1”, then you may have the wrong device. I use the “EVF-DC2” with my M3. I think the “DC1” is designed for Powershot Series, not the M Series.
06-12-2022 11:48 AM
The EVF-DC1 works Perfectly with the M3. It is, in fact, an accessory listed in the M3 user manual.
My issue is with the M6 MII.
06-12-2022 12:25 PM
The DC1 is what was available when the M3 was released. The DC2 is the recommended accessory for the M6 Mk II
06-12-2022 12:38 PM
The DC2 is recommended, in part, because Canon no longer sell the DC1. Which I feel is a shame because I use the articulation of the DC1 often.
I'm aware that it Might be a communication issue, but there is no reason it should be. And I am trying to find out if it is definitely insolvable or if it is a bug in my particular camera.
06-12-2022 12:34 PM
Take a look at this link. Tap the “What is in the box” button.
06-12-2022 01:52 PM
This does not answer my question. That they include the currently manufactured evf instead of the no longer manufactured evf says nothing to compatibility.
And I just discovered a VF display menu which solves the problem.
06-12-2022 01:53 PM
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
