07-29-2017 01:10 PM
Hello all, I have just started getting into this photography game (literally 3 weeks ago). I brought a 750D and popped out snapping away to just get used to it. When in
ooked back at some photos I noticed some light spots. All in different places and different sizes. I've tried to attach the photos. Any advice would be welcome as hoping it's me and not the camera. Thanks.
07-30-2017 11:43 AM
Thanks for the response Scott, I've looked into cleaning the sensor I think it may be something that I can do myself?? None of the photos have been cropped or altered, they are as they were taken. It's all a bit odd. I've had similar things on photos taken with an iPhone too.
07-30-2017 12:01 PM
@Harry6 wrote:Thanks for the response Scott, I've looked into cleaning the sensor I think it may be something that I can do myself?? None of the photos have been cropped or altered, they are as they were taken. It's all a bit odd. I've had similar things on photos taken with an iPhone too.
Glad you asked. Never touch anything inside of the camera body. Use an air blower. Leave physical cleaning to professionals. It requires more tools than the average person will typically have.
07-30-2017 12:14 PM
Hi Harry6!
Welcome to the Canon USA Community!
One thing that I thought for sure someone would ask - what mode are you using on your top dial? Is your flash going off? Are you using an external flash? The reason I ask is because in the photos where we can see the "orbs," it looks, to me, like flash illuminated dust/particles in the environment.
If you were shooting in A+/Green Box/Auto mode (or anything other than P/Tv/Av or M), your flash could have gone off to either help with focusing, or to help with low light (in the first set of photos).
In the cloud photos, I do see what looks like a dust particle on the left 1/3 middle half of the frame. You can try to clean it yourself with a blower, but do not touch anything in your camera.
Take a look at the following YouTube video from Canon USA on how to clean your sensor yourself HERE.
07-30-2017 12:32 PM
I am not sure what it is but I can tell you what it isn't. A dirty sensor, yeah, your sensor may be dirty but that didn't cause the white spots. It is not a flash either. I also doubt it is a dirty lens. And for sure it is not firefly's!
Since nothing showed up in the sky photos, no white spots, just keep using the camera for a while. You may see a pattern that will allow you to find the answer.
IMHO, leave the sensor alone. People over estimate the value of sensor cleaning as well as lens cleaning.
07-30-2017 12:55 PM
Hi thank you for that Stephen, I was in full auto for the first three photos and the flash did go off so that makes sense. However the light in the sky photo today was taken in AV (whatever that is)
07-30-2017 12:56 PM
I'm glad I asked too. Going to take it back in to get someone to have look at it. 👍
07-30-2017 12:59 PM
Thank you for that. It is a nightmare being clueless but I'm sure it'll get easier...... won't it 😉
07-30-2017 01:09 PM
Hi Harry6!
It will get easier! The more you practice, the more buttons you press, and the more questions you ask!
Here's another little favorite of mine - our EOS 101 series on YouTube - it's just a little primer to get you familiar with what your camera can do. The rest is up to you!
07-31-2017 07:05 AM
08-01-2017 04:05 PM - edited 08-02-2017 03:53 PM
@Harry6 wrote:
Thank you all for your help and contributions. In the end I bit the bullet and took the camera back. They were very helpful and gave me s new one. Hopefully better luck with this one....
like Arnie I'm sure "I'll be back". For more help... cheers. 😉
A new camera is going to act the same way when shooting in low light with the flash when there is "stuff" floating in the air in front of the camera within the flashe's range.
Camera Maker: Canon
Camera Model: Canon EOS 750D
Lens: EF-S18-55mm f/3.5-5.6 IS STM
Image Date: 2017-07-26 20:19:49 (no TZ)
Focal Length: 55mm
Aperture: ƒ/5.6
Exposure Time: 0.017 s (1/60)
ISO equiv: 1250
Exposure Bias: none
Metering Mode: Matrix
Exposure: program (Auto)
White Balance: Auto
Flash Fired: Yes (Auto, return light detected)
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
I noticed in the EXIF data for the first three shots that the flash was fired. I think Stephen has it figured out as the flash has illuminated some bits of airborn dust and debris. Lens cleaning won't eliminate these spots. Cleaning all the air in your field of view might help, but it's probably easier to shoot without the flash if you can.
