07-29-2017 01:10 PM
Hello all, I have just started getting into this photography game (literally 3 weeks ago). I brought a 750D and popped out snapping away to just get used to it. When in
ooked back at some photos I noticed some light spots. All in different places and different sizes. I've tried to attach the photos. Any advice would be welcome as hoping it's me and not the camera. Thanks.
07-29-2017 07:48 PM
Dirty sensor. To test shoot the empty sky at f 16 or higher. They may not show up at all near wide open apertures but as the aperture gets higher you see them. It could also be dirt on the inner lens element.
07-29-2017 07:56 PM
I am tempted to say out of focus fireflies. Dirty sensors tend to produce dark spots because the light is blocked from reaching the sensor.
07-30-2017 04:53 AM
Thank you, I'll test this later on around the same time and let you know how it goes.
07-30-2017 09:31 AM
@Harry6 wrote:Thank you, I'll test this later on around the same time and let you know how it goes.
Heed the previous advice, and take a picture of a clear sky when the sun is high in the sky, just the sky and not the sun.
07-30-2017 10:36 AM
Right then, I have tried the sky shots with two different spots. One darker in the same place on a few photos ( I'm thinking dirt on lens) and one light spot only on one photo, which also has the dark spot on.
07-30-2017 10:41 AM
Are they at f16 or f22. You need to be at a high f stop number for the test.
07-30-2017 10:44 AM
F20
07-30-2017 10:52 AM
Also just tried cleaning the lens to no avail. 😩
07-30-2017 11:29 AM
In all 3 of your sky pictures you can see some dirt on the sensor. It is a dark spot on the left side, and it is in exactly the same place in every image like dirt will always be. It is even possible to program your post processing program to automatically fix these dark spots for a while, until you get around to doing a cleaning, because they do not move.
So two odd things about your light spots.
1.) Your light spots pots are not dark like dirt but light. I suppose it could be water droplets. They seem to catch the light and reflect it and the one in the cloud almost has a prismatic quality. ??? Does anyone else know any other reason how/why these would be light spots instead of dark?
2.) The other odd thing is that the light spots are in different places in different shots, and sensor dirt does not move. Are you maybe cropping some of those, making the positions of the light spots change location in the frame?
