01-18-2017 01:13 PM
I just inherited this camera...Rebel EOS xsi...learning to use it. Obviously I punced the wrong button, no doubt...now the LCD's okaybut can't access the menu or see image playback.....what'd I do and how canI correct this????
01-18-2017 01:21 PM
Did you ever see a menu display? Do you have a copy of the insruction manual?
https://www.usa.canon.com/internet/portal/us/home/support
Use the above link to navigate to your camera's product support page. From there, you can download the manual and camera software.
The <MENU> button is used to display the menu. You may have a bad button. What happens when you press <DISP> a few times?
01-18-2017 01:30 PM
I have the manual...the settings, display and everything was working fine until I tried to change settings...now I see settings when camera is on, but when I try to display menu nothing happens, and when I hit display it's a dark screen...no image.
01-18-2017 02:36 PM
@nelliemae wrote:I have the manual...the settings, display and everything was working fine until I tried to change settings...now I see settings when camera is on, but when I try to display menu nothing happens, and when I hit display it's a dark screen...no image.
It almost sounds like your display has died. Change your memory card. Does Live View show an image?
01-18-2017 03:26 PM
Hi Nelliemae,
Thank you for posting.
I recommend that you reset your camera to its default settings. Here's how:
![]() | Select [Clear settings].
Select the desired setting.
Select [OK].
01-18-2017 04:42 PM
I don't believe the XSi *has* live view.
01-19-2017 10:21 AM
Thanks everyone...I figured it out and it's doing fine! I just managed to get the menu up and readjusted the settings. Somehow I'd turned off the review function for photos.
Cheers,
Nell May
