LC-E10 charger/battery not working?
Gatorade92
I bought a brand new Rebel T6 and it seems that my battery is not charging.  My product came with a LC-E10 battery charger.  When I put it into the power outlet, the 'charge' LED will blink every 1 second.  I am disappointed the owners manual says nothing whatsoever about the display light blinking or being solid.
I have left it charging for up to 3 hours yet when trying to power on the camera, nothing happens.
my best guess is that the battery is completely dead/unrecognizable to the charger.  Does anyone have experience with this issue?
30 REPLIES 30
Gatorade92
Lol ok I'm not ignoring your advice or having anything "my way".
If anything I would hope the owners manual would put emphasis on an initial charge process, which makes sense and I'm trying that now.
Gatorade92
If anyone is wondering, I got a different result using the same charger with a different battery
this time, with the new battery the 'charge' LED stayed solid and didn't blink at all.  After two hours of charging, it was fully charged.  My problem was certainly unique to the original battery I was using.
Alpha97
Hey. My Lc-e10 chager blinks about once or twice a second without the battery being inside. Amy solutions?
Alpha97
Sorry for the grammar.
Alpha97
Hey. My Lc-e10 charger blinks about once or twice a second without the battery being inside. Any solutions?
That's not right.  Buy a new one.  Unplug that thing before it starts a fire, too.
Hi Alpha97,
Thanks for posting.
So we may better assist you, please let us know the camera model you're using.  In addition, please let us know when you purchased it.
Bought a Rebel T6 in December 2016. Battery charger is an LC-E10 for battery LP-E10. Initially charged battery as required. Used the camera sporadically from January to August. Charged the battery 2-3 times during that period. Have not used camera until this week (December 1st). The battery has a very low charge as indicated in the display. The charger will not recognize the battery -- no lights come on. Have cleaned the contact terminals, no change. One would think the charger would last more than a handful of charges. Any suggestions other than buy a new charger? Thanks.
I'd be more inclined to suspect the battery of being the problem, rather than the charger. If you have only one of each, I'd suggest that you buy a new battery before before you consider buying a new charger. Ideally, you should have a spare of both; but a spare battery is more of a necessity, and a charger is less likely to fail.
When in last December did you buy the camera? Whichever device is failing may not be out of warranty.
Bob
Thanks Bob, The battery still was powering the camera, so I deferred to a new charger. Found one on ebay for $16 and free shipping. If it does not work, then I will get a battery replacement. Canon's warranty on the battery and charger is 90 days. Thanks again for taking the time to reply.
