10-13-2025 12:33 PM
I mainly shoot in manual mode with auto ISO but do like to shoot in Av mode sometimes.
I'm wondering if there is a way to set a minimum shutter speed when in Av mode specifically for the R10. I don't want the shutter speed to go below 1/250 when in Av mode. I've looked at a few boards and online resources but can't seem to find a clear answer. I've also seen somethings that there are different settings or methods based on manual ISO vs auto ISO?
Screenshots walking through how to set it up in the menu settings would also be super helpful.
10-13-2025 03:03 PM
10-13-2025 01:05 PM
In the RED camera menus, there should be a setting on the 2nd screen called “ISO Speed Setting”, or something very similar. If you go into that menu, you should find a submenu that allows you to restrict shutter speeds.
10-13-2025 03:03 PM
Like this(from R10 manual):
10-13-2025 05:10 PM
Thank you!
