06-13-2013 05:45 PM
What ISO setting do you use most often and why?
06-13-2013 05:55 PM
100. It has the least noise and I like to use off-camera flash, so light isn't usually an issue..
06-14-2013 05:42 AM
I also like using ISO 100, and use off-camera flash. However this depends largely on the available ambient lighting, and what type of image I'm trying to create, and how my final image will be used or shared. If it's for print then yes, I'll stick with the lowest ISO. If the image is just for web viewing, then I can get away with using a high ISO if need be. I'm willing to trade some noise for getting the shot. I have shot some photos with ISO 3200.
06-14-2013 12:07 PM
