I have no visible menu on Canon EOS2000D
TanguyBas
Hello Guys, I'm using a canon eos 2000d.
I had a problem with my camera screen. So I decided to open it up to fix the problem. I removed the rear panel (with the LCD screen and buttons). To do that, I disconnected the 2 ribbons connected to the LCD panel, as well as the white connector with the wires, fixed my problem. Then reconnected them.
The problem is that now when I turn on my camera, I don't get a menu. My screen is on, all the functions work (flash in and out, picture taking, LEDs...) but I don't have a menu displayed on my screen.
As troubleshooting, I tried to redo twice everything to make sure all the ribbons are connected. I'm also making sure that the battery port is closed. !
Could you please help me. Do you know how the menu is supposed to appear (which ribbons or sensor or connector is in charge of the menu...). What can I try to locate the problem.
Many thanks.
1 REPLY 1
Waddizzle
I am afraid your camera needs to be serviced by a professional, or possibly replaced.
