08-22-2018 09:40 PM
Camery : Canon EOS T6s
My PC : Windows 10 Home 64b. 1803
Question: How to recharge the battery of T6s without taking it out of the camery?
The camera has been connected to my PC by its micro USB cord. I have not yet found any option for recharging the battery or any indication on the camera body.
Thank you.
Kuen
08-22-2018 10:10 PM
You can't. The USB cable cannot charge the battery or even power the camera while it is plugged in.
08-22-2018 10:55 PM
Thank you, kvbarkley.
Does it mean that the battery must be taken out of the camera for recharging?
Thanks.
Kuen
08-23-2018 12:55 AM
Have you read the manual? It's pretty clearly explained...
08-23-2018 02:52 AM
@kvbarkley wrote:You can't. The USB cable cannot charge the battery or even power the camera while it is plugged in.
08-23-2018 09:20 AM
Yes, you must take the battery out and use an external charger. One reason is that Canon uses relatively high voltage batteries - my T6S uses the 7.2 Volt LP-E17 - which is higher than the 5 V USB supplies. This makes it impractical to charge the battery directly from USB*. My Olympus TG-5, on the other hand, uses a 3.6 V battery so that it can be charged from USB, and in fact is the standard way to do it.
* Yes, I know all about step-up DC-DC converters, but to charge the relatively large capacity Canon batteries in a decent amount of time would take too much current from the USB.
08-24-2018 04:30 AM
Thank you, Kvbarkley.
Really appreciate the explanations why Canon does not recharge the battery directly with it in the camera body. I have been using a Sony a7II since it was out. It recharges the battery diredtly from my PC or laptop whenever I download the images. Convenient but Sony's battery is not so strong as Canon's.
Thank you again. Really appreciate.
Kuen
08-24-2018 11:09 AM
"Have you read the manual? It's pretty clearly explained..."
Who buys a nice camera and doesn't even pop the manual. This is right in the front of the manual. There is going to be a whole host of other things you won't know how to do I have a feeling.
