11-28-2014 07:34 AM
Hi!
This seems like a very basic question, but after searching the manual and the web, I still can't find an answer.
When I half-press and release the shutter button, the camera turns on the display on the viewfinder that shows the shutter speed, aperture, exposure level indicator and ISO speed. But it automatically turns off after about 4 seconds. I've looked through all the menus and I can't find how to increase this timeout so the information is shown for a longer period of time.
Help?
Thanks!!
11-28-2014 03:11 PM
I don't believe that is an adjustable value.
11-28-2014 03:11 PM
11-29-2014 09:32 AM
Neither do I.
But, I thought it only shut off when you pressed the shutter button again? I have forgot but I can look at my son's T3i and see.
11-29-2014 09:44 AM
@ebiggs1 wrote:Neither do I.
No, if I half-press and release the shutter button again, it resets the timeout and the display on the viewfinder won't turn off for another 4 seconds or so.
Just to be clear, I'm not talking about the main 3'' LCD display (which I only use to review photos, not to shoot). I'm talking about the display on the viewfinder that only shows shutter speed, aperture, exposure indicator, ISO, and a few other things like an asterisk for exposure lock or a circle for focus lock.
I would really appreciate it if you could see if it works the same way or if you can change it on your son's T3i.
11-29-2014 09:48 AM - edited 11-29-2014 09:50 AM
You are talking inside the viewfinder? OK, I msiunderstood, no, I believe that is normal and is not an adjustable feature.
11-29-2014 09:49 AM
OK, thank you both for your help!
11-29-2014 10:20 AM
11-29-2014 12:28 PM - edited 11-29-2014 12:29 PM
@jrhoffman75 wrote:
You actually control the "on time" to any value you want by keeping your finger on the shutter button.
I find it awkward to change the exposure while keeping my finger on the shutter button. I am a beginner that just started using Manual mode. It takes me a while to get the exposure metering to where I want it to be, and it's annoying that it turns off long before I get it to where I want.
11-29-2014 01:46 PM
I have a T5i, so I am not sure its exactly the same as your camera, but in Manual mode, as long as I am turning the main control dial (one near shutter button) the viewfinder display stays on.If I stop, then the timer kicks in again.
11-29-2014 01:59 PM
@jrhoffman75 wrote:I have a T5i, so I am not sure its exactly the same as your camera, but in Manual mode, as long as I am turning the main control dial (one near shutter button) the viewfinder display stays on.If I stop, then the timer kicks in again.
The same happens on the T3i. I guess this will be enough once I practice and get faster (since people shoot in Manual mode and don't complain about this). Thanks!
