12-09-2023 02:06 AM
I’ve been struggling for a long time to connect wifi to my iphone. When I try to ‘clear settings’ under ‘communication settings’ it is blacked out and can’t be selected. As is the ‘nickname’ option.
Please help?
12-09-2023 01:33 PM
You have to set a nickname in the camera first to be able to change wifi settings. So if you cleared the wifi settings this remove the nickname, so the first step is to set a nickname.
See the manual page W-8
12-09-2023 06:01 AM
Make sure Wi-Fi communications is enabled.
The camera will communicate using USB or Wi-Fi. You mist tell it which method to use. The camera is not able to switch back and forth on its own, and you would not want it to, anyway.
12-09-2023 01:33 PM
12-09-2023 10:00 PM
Thanks very much. Upon clearing nickname and renaming it somehow connected to wifi etc. appreciate this
