09-01-2019 05:58 AM
Helow..I have problem in my canon eos kiss X10. When I using my external microphone theres a noise its like a eletric noise ..I dont know if the sucket is the problem or the cable./.when using internal mic I dont have problem..I dont have problem before about using external mic but now I dont know there is a noise..please help me guys//I cannot explained well Im not good english..
09-01-2019 11:14 AM - edited 09-01-2019 11:27 AM
Some comments and things to check:
-Ensure the connector on the external mic is clean and in good condition. (cord is not kinked or bent)
-Ensure the port on the camera is clean, free from excessive dust, etc.
If you have another mic to test with try that too
If the mic is powered and has gain adjustment, try turing it down
Camera Settings:
There are Auto / Manual input, gain, Wind Noise Cancellation and Attenuator features. Experiment here as some might work better depending on the brand of external mic.
09-01-2019 09:15 PM
Thanks to your help sir..I checked the cords now I think there is no problem with the connector because I already try to my loptop but the sounds was good. I also cleaned now the socket of the camera but still there is a noise. I don't have extra cords or other microphone to test so that I can confirm if the socket of the camera is the problem. I also enable the wind filter but still have noise..I will try if I can buy a connector or another mic so that I can confirm what is the problem. I think its a shortage or a grounded.. I dont knOW But anyway thank you for your help
09-02-2019 08:25 AM
@Nelvin wrote:Helow..I have problem in my canon eos kiss X10. When I using my external microphone theres a noise its like a eletric noise ..I dont know if the sucket is the problem or the cable./.when using internal mic I dont have problem..I dont have problem before about using external mic but now I dont know there is a noise..please help me guys//I cannot explained well Im not good english..
You have the wrong type of microphone. Some microphones require phantom power, while others do not. Some microphones have balanced outputs, while cheaper models have an unbalanced output signal.
This is also true of the microphone input connection. Some connections can provide phantom power to a microphone, while others do not. Some microphone inputs are balanced, while others are unbalanced.
I would guess that your camera has a plain old-fashioned microphone input: unbalanced and unpowered. Does that match the type of microphone that you are using?
09-03-2019 02:19 AM
Thank you . That mic is cheap only...now I already ordered again new boya by-mm1 microphone to confirm if the problem is mic or the socket. This cheap mic before I dont have problem but after a months and now there is a noise ...I hope that if the mic is the problem its okay but if the socket of the camera is the problem that is a big problem. Thank you..
09-05-2019 06:23 PM
09-06-2019 10:06 AM
Glad to hear it. Often times with these types of things you get what you pay for.
