02-04-2021 09:18 PM
In the spec sheet it almost doesn't explain this at all. Neither in the manual.
I tried to figure this out by shooting all shutter mode/shooting mode combinations and try to check it on my PC, however:
using exiftool it all shows up as 8 bits: "bit per sample: 8 8 8; compression: JPEG (old version)." This makes no sense.
My goal is to determine if I should be using continuous modes and which shutter to use.
Anyone got any ideas?
And why are the RAW files labeled as 8-bit jpegs?
02-04-2021 10:31 PM
I believe that is the jpeg preview embedded in the file.
There are sites that explain the cr2 format in excruciating detail if you want.
02-04-2021 10:32 PM
@kvbarkley wrote:I believe that is the jpeg preview embedded in the file.
Thanks! Do you know how I can get rid of that so it shows the raw's information?
02-05-2021 09:26 AM
The raw info is proprietary, I don't know that EXIFtool understands it.
02-05-2021 12:36 PM - edited 02-05-2021 12:37 PM
You might look into the RawDigger app to see if that gives you what you want.
