12-09-2022 09:38 PM
I was shooting a proposal today and shooting on dual SanDisk cards as I always do. Half way through the session card #2 prompted that it was full so I removed it and continued shooting on the second card. At the end of the session I checked my images count and it was around 450. I wrapped and returned to the card. When I started reviewing images again my image count had dropped to 380. As I began investigating there are 70 images missing from the first 10 minutes of shooting. My file naming jumps from image 5748 to the next being 5821, with the timestamps being 2:18pm and the next 2:33pm. I was shooting continuously though this time, and on both cards. I then went back and check the 2nd card, which they are also not on. I tried restarting the camera. I tried viewing both card on my computer, and nothing. I am at a loss for how this could happen on two cards at the same time, especially for such a large chunk of time. I was not shooting rapid fire or anything volume wise that would stop the camera from syncing. I just dont know what could have happened. Please help!
12-09-2022 09:59 PM
When you tried viewing the cards on a PC, were you using a card reader or trying to view directly from the camera? Try a card reader.
I would also try a file recovery software.
12-09-2022 10:42 PM
Unfortunately I was using a card reader, images are not there on either card and both show the skip. I am working on file recovery software now. I'm just at a loss for how that could happen on two cards simultaneously.
12-10-2022 09:10 AM
Possible scenario
1. sounds like you were recording to both cards and one card had more available storage than the other.
2. Not sure about the R6, but, when set up to record to both cards, my DSLRs will stop recording if one card becomes full. Protection against not having images on both cards, which was the intended setting.
3. Is your camera perhaps set to enable shooting without card?
4. Were you always checking the LCD or could you have perhaps missed when the camera first signaled Card Full?
In other words, did your particular shooting configuration allow the camera to continue to shoot when one card was full but installed, and recording resumed when the card was removed and the camera started recording in single card mode.
09-14-2023 01:24 AM
Did you ever recover the images? In the exact same position!
09-14-2023 01:24 AM
Can images still be recovered though, in these scenarios?
