ERR 05
krystinamendez9
I keep getting the Err 05.  Different from the other inquiries on this site, my flash pops up and is not stuck.  However, it does this even in the sunniest of days when I don't need the flash.  It then clicks and won't allow me to take pictures (after the flash is up).  It is extremely annoying, as I am taking action shots and need the continuous setting, but because the flash is waiting to set, it delays the picture taking too.  It will happen over and over again.  I do what it says, turn it off and on again and pop the battery out.  It is quite annoying and VERY frustrating!!!
2 REPLIES 2
diverhank
Sorry to hear about your problems.  It appears you may need to send it in for service.
Not sure which camera model you have but in general, you should be able to set the option to never use flash (either on the mode dial and/or via the menu option). I'd do both.
You should try disabling the flash and see if you can avoid the annoying problem.
Diverhank's photos on Flickr
ebiggs1
Whatever camera you have, it needs Canon service.
EOS 1DX and many lenses.
Friends and Family
