08-01-2015 01:27 AM
08-01-2015 10:01 AM
@Triciaan wrote:
The image does not appear in the screen. Only the image setting information shows. How can I change it back to show the image? Thanks.
The 400D doesn't have a "live view" mode, so you can see only pictures that have already been taken. To activate that capability, push the small button with the blue arrow head on it. Then use the two buttons to the left and right of the "set" button to select which picture to view.
It sounds as though you don't have a user manual. You can download it from Canon's Web site. Since the 400D is no longer made, it won't be on the page with the current cameras. But poke around in the "support" area and you should be able to find it.
08-01-2015 10:01 AM
08-01-2015 07:40 PM
08-01-2015 08:14 PM
