ā05-02-2025 10:23 AM
My touch feature does not work. It is enabled. I tried default and sensitive settings. Is there a way to calibrate it? How can I fix it?
ā05-02-2025 10:37 AM
I would cal Canon 1 (800) 652-2666 and get it looked at ASAP because it will be out of service life if not already very soon.
ā05-12-2025 04:42 PM
Thank you. I called and the cost to replace the screen was between $179 and $300 and black I would have to mail it in. I found a new one on ebay for about $80 from China but I don't want to order from China. I will keep looking for other touch screens. Until then I will get used to using my buttons instead of the touch screen. To replace the screen requires removing 6 screws with eyeglasses screwdriver so I will do it myself if I find a screen in the USA.
