Canon EOS R6 Mark II LCD screen glitching in the cold
Linkanini
I recently purchased a Canon R6 Mark II and have noticed that the screen glitches. After some time it starts generating white lines from the bottom which gradually turn red/pink. Additionally, at the top of the screen, some elements flip. This only happens when using the camera in colder weather, around 3-6°C. I am still able to use the camera, and the viewfinder and images are fine. I have reset the settings but have still been able to reproduce the glitches without memory card and lens attached. Does anybody have the same experience? What would be the best way to solve this?
Removed link per forum guidelines
1 REPLY 1
NatalyaP
Greetings Linkanini,
I'm sorry to hear that your camera is having screen issues when the camera is used in cold environments. Per review, the operating temperature for the EOS R6 Mark II is 0–40°C / 32–104°F. If it's windy or there's humidity in the air, it may drop the temperature even lower where we cannot guarantee optimum functionality when the temperature is outside of this range.
If you are concerned about the functionality of the camera, you may send the unit to our facility for repair.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
