EOS T3i not taking photos
Phillylady
1. It turns on
2. The lower right green dot, as viewed through the eye viewer, flashes off and on when I press the shutter button.  Nothing happens beyond that.
3. The button will not go half way down to focus, and it will not click to take a photo.  Therefore it is not focusing, or taking a photo.
4. None of the other settings will take a photo either,
5. EXCEPT when I put it into video. It will record video and SNAP A PHOTO while I am in video.
6. I have removed the battery and reseated it three times, it is fully charged and I've also tried using a 2nd battery. This is not the problem.
7. I have removed the photo card and reseated it 3 times.  It has tons of memory room left on it.
8. I have removed the lens twice, and wiped the contacts (which look pristine as I normally never remove the lens).
9. The camera is definitely set to AF.
I'm trying to figure out if some other setting on the camera inadvertently got shifted, but for the life of me I can't figure out what that would be. I'm not adventurous with the camera and just use the bare basics.
At the time that this happened it suddenly showed reluctance, I had to press down several times to finally get it to snap two final photos, and then it suddenly locked up completely.  It hasn't been banged, or knocked around, so I am mystified.
If you have any suggestions it would be really helpful if you could put them into layman's terms.  Pretty please.
Correction, after awhile, after doing the reset, suddenly it began to work again.
Thanks for all of the help everybody!  I have absolutely no clue what it was unhappy about, but it seems to have corrected itself.
10 REPLIES 10
Waddizzle
Try this!  Put the lens AF/MF switch in the MF position.  If the camera takes a picture, then i suggest that you download a copy of the Instruction Manual.  There are a long list of things that are going wrong, and 90% of them are user error.
Okay, I just tried putting it into MF mode, and it does take a photo without hesitation. I have the manual that came with the camera and looked through the Troubleshooting list, but none of the things in there seemed applicable. I will double check again, and then look at the one online to see if it's any different. I'll get back to you if it's resolved.  Thanks!
There is a setting that prevents the camera from taking a picture if the lens (in AF mode) was unable to achieve focus (low light, too close to the subject, or whatever). I'd start by reading the part of the manual that deals with that phenomenon.
Video and live view use an entirely different focusing system. So the fact that those modes work is probably irrelevant.
Bob
ebiggs1
"I'm trying to figure out if some other setting on the camera inadvertently got shifted, ..."
Whenever you have a situation where things don't work as you expected. do a camera reset.  This brings you back to a factory default status.  It is usually in the Tools menu and is Clear all settings.
Now that, that is done, Phillylady, go outside on a nice day. Sunny bright!  Set the T3i to the green square on the mode dial and the lens to AF on the AF/MF switch.  You can also use the P mode if you prefer but do not use any other mode at this point.  Green square or P only.  If all is well and the T3i worked as it should there is nothing wrong with the camera/lens combo.
Either way, if it worked or not get back and I can suggest some more stuff.
EOS 1DX and many lenses.
Unfortunately that doesn't seem to change the situation.  I've looked through the manual, changed the settings to default (not that I'd changed them to begin with, but just in case).  And it works in manual mode, but I can't see well enough to manually focus the image manually.  Sigh
"... but it seems to have corrected itself."
I would bet on the reset in favor of it fixing itself !  Smiley Happy  Keep it in mind if/when it ever happens again, kido.
Well, it turns out that my response was premature. Sigh
It turns out that it is indeed now taking photos in Automatic setting.  However, the automatic focus is not participating. So, all of the photos are unadjusted, fuzzy, and some of them will not come up when I try to view them on the computer.
"It turns out that it is indeed now taking photos in Automatic setting."
OK this is good.  If this works it is a good indication that nothing is wrong with the camera.
"...  the automatic focus is not participating."
Check the AF/MF switch on the lens.  Is it perhaps set to MF ?
"... some of them will not come up when I try to view them on the computer."
This is not a camera issue most likely.  You need to look at your computer and its software. Maybe a bad USB cable or USB port.
