EOS Rebel T8I Can't select SCN Mode
kujhawk1978
On my Canion T8i, I cannot select the SCN mode, it is greyed out.
I've tried resetting the camera to factory settings, doesn't work
15 REPLIES 15
Is that with the mode dial set to SCN Mode?
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Is that with the mode dial set to M Mode?
-Demetrius
With the dial set to M, the shotting Option is AV on the screen, with SCN, it's P
The rotary encoder switch under the mode dial is not working correctly. Canon will have to repair your camera. But get a QUOTE FIRST before repairs are made. To see if your camera repair is your best option or if it cost prohibitive. If repair exceeds the cost of the camera then replacement may be warranted. Rebel Series cameras can quickly exceed the cost of repair.
-Demetrius
Thanx
kujhawk1978,
I'm afraid Demetrius is right. I think you have a technological problem. You aren't doing anything wrong, and no settings change you could make will fix your problem.
It's time for a repair job.
Steve Thomas
