04-02-2021 06:24 PM
My Canon EOS Rebel T6i started having partial blackout problems on preview displays that also block out the same area on all images (about 35-40%). I have removed the battery and tried turning on the camera and pressing the shutter button for 10 seconds. I've also tried clearing all camera settings and functions to default. Please advise. Thank you!
04-04-2021 08:43 AM
@MartyE wrote:Interesting. Looking at the black piece, it appeared to have straight sides making a long rectangle. Thanks for your suggestions, I'll try taking it in somewhere to see what my options are. How do I contact Canon Support?
I could post the link, but this is how to find it yourself. Click on the word "Canon" in the top left corner. This will take you to the Canon Community Home Page. There is a link to "Canon Support and Service" halfway down the page, on the left side.
Click in the link, and a new tab/window will open in Canon Support. Follow the instructions. Type "Rebel T6i" in the box, and when you see a selection for "EOS Rebel T6I" appear, click on it.
You should now be at the Canon Product Support Page for the Rebel T6i. There are links to contact Canon Service at the upper right half of the page. You can contact them via email or phone.
04-02-2021 09:59 PM
IF the images are fine when imported to the computer, it sounds like a bad video card or LCD. Try plugging in an HDMI monitor to see if the same thing happens.
Either way, it needs to be sent to Canon to be fixed.
04-03-2021 01:15 PM
Unfortunately, the images show the black bar. My spouse and I discovered the problem inside the camera body by selecting "clean the sensor - manually." When the mirror folded back, we saw the black thin plastic "bar" that was out of place causing the problem. We were unable to get this plastic piece rearranged successfully to prevent the blockage on Live View and the image. Is this problem something that can be repaired at a local camera store, or do we need to ship it back to Canon? I am also wondering if I would be better off purchasing a new Canon camera body that can be used with my T6i kit lenses?
04-03-2021 02:14 PM
If you can seen the entire menus, then you may have a bad shutter. Can you post a sample image of the issue? The cost to repair is probably close to the cost of used camera of the same model by the time you take postage into consideration.
04-03-2021 03:24 PM
This sounds like the kind of thing a local camera shop can do.
I hope you did not scratch the sensor trying to dislodge it.
I would get an estimate and then decide whether to get a new camera.
04-03-2021 04:56 PM
Here is a test image once I noticed the problem. Thanks for your input!
04-03-2021 06:51 PM
Yikes!
Yeah, that looks like shattered shutter. Let a reputable local camera shop look at it. Bring your cell phone with that sample image stored on it. The prognosis does not look good. Canon Support would be the best place to seek advice, though.
04-03-2021 07:13 PM
04-04-2021 08:43 AM
04-04-2021 05:50 PM
Thanks so much!
