06-13-2024
07:58 AM
08:08 AM
Hello, I just got a Canon EOS rebel t6. It was a hand-me-down so I'm not quite sure how old it is. Anyway, I love it but the only thing is that my pictures turn out quite underexposed when I am in TV mode and I make the shutter speed fast. This isn't really ideal because I do bird photography and the higher speeds are really helpful. I also noticed that the f-stop stayed at 5.6 no matter what shutter speed it was at. Is that bad? The only other thing I could do was put the ISO on high. Can you please help me.
(I just switched from a PowerShot to a DSLR so I am pretty sure my problem might be ignorance)
06-13-2024 09:19 AM - edited 06-13-2024 09:21 AM
Maggie,
Your aperture determines how much light is let into your camera. Your shutter speed determines how long your camera is exposed to that available light. With really fast shutter speeds, it's just the blink of an eye.
In lower light situations, that might not be long enough to give your camera time to properly or adequately expose your picture and they come out dark. In Tv mode, The camera tries to compensate for that by lowering, or widening your aperture.
Depending on the lens that you are using, an aperture of 5.6 is probably the lowest it can go as you zoom in.
Your best bet is to put your camera in Auto ISO and let your camera raise its sensitivity to light as much as it can.
Steve Thomas
06-13-2024 09:11 AM - edited 06-13-2024 09:12 AM
What lens?
It does sound like there might be a shutter issue.The aperture thing is weird. Can you change the aperture setting in manual mode? Does the DOF preview shut down the aperture?
Maggie,
Steve Thomas
06-13-2024 10:11 AM
Thanks so much for your insight. I was able to get well exposed pictures outside when I put the aperture at 3.5 (in manual mode) and put the ISO on Auto. I think I had accidentally messed with it. Thank you again for your help.
-maggie
06-13-2024 10:13 AM
I was able to change it in manual mode. I'm not sure what a DOF is, but I was able to fix it. I had just accidentally touched the ISO. Thank you for trying to help me (:
-maggie
06-13-2024 12:06 PM
DOF preview is the button on the front of the camera that will stop down the lens so you get, well, a Depth of Field Preview.
