04-30-2020 11:09 AM
04-30-2020 11:13 AM
Is the lens auto focusing? Try it with the lens switched to MF. The shutter should be able to fire even without a lens attached.
04-30-2020 11:13 AM
04-30-2020 11:29 AM
04-30-2020 11:55 AM
It sounds like there is an issue with your lens not auto focusing. Again, does it work with the lens switch set to MF?
04-30-2020 04:16 PM
04-30-2020 04:40 PM
*Exactly* which lenses do you have.
04-30-2020 05:00 PM
04-30-2020 06:00 PM
@kvbarkley wrote:*Exactly* which lenses do you have.
The kit lens in every factory T6 kit that I have seen contain the EFS 18-55mm f/3.5-5.6 IS II. I'd bet the AF motors are jammed from accidentally turning the AF ring, instead of the zoom ring.
05-01-2020 09:02 AM
My thought, too.
There is a procedure to pop it back in place, you can search this site.
05-01-2020 09:58 AM
