03-05-2025
07:27 PM
07:52 PM
Tiffany
Hello, I have a canon t3i rebel that I have used for quite some time and just earlier this week, I got an error message on my camera saying that my memory card was protected and that it wouldn’t let me take photos. The switch wasn’t down so I thought maybe this was the card itself so I got a new one. The same exact message showed up for a new card, I checked for debris in the card slot and could not see anything. Thanks.
03-05-2025 08:10 PM
I’ve had it for about 5 years.
03-05-2025 08:13 PM
Are any pieces of the old SD Card broken off in the card slot. Inspect carefully with a flashlight and check the original SD Card for any broken pieces. If clear then the fault is with the camera.
03-06-2025 02:12 AM
Do you only have one SD card? Trying another one will tell you what's what. A 16 or 32 GB card is cheap.
03-06-2025 10:26 AM
Unfortunately I have tried 3 brand new ones and unfortunately everything said the same thing.
03-06-2025 10:38 AM
You have never said whether you have inspected the inside of the slot. Take a long, thin tool, and try to exercise the little switch that engages the write protect tab. It may be stuck
