08-01-2014 12:01 AM
Hi I have a EOS Rebel T3i. My flash will come up but doesn't work, how do i fix this?
08-01-2014 11:38 AM
How is it not working? Doesn't pop up and/or doesn't fire? What shooting mode are you in? We need more information to help you.
08-02-2014 08:51 AM
The pin that tells the camera the flash is open is probably dirty. Try a few small drop of denatured alcohol on it.
Do not use any thing else.
08-03-2014 01:24 PM - edited 08-03-2014 01:24 PM
harneetaujla, I think you might have the camera in "Auto Flash" mode. In this mode, the flash fires automatically when necessary. If the camera is in "Flash on" mode, the flash always fires. See page 58 of your manual.
You don't say what settings you are using, so it's a bit difficult to troubleshoot.
08-05-2014 08:47 PM
The flash pops up but won't fire and i can't figure out why cause we haven't used the camera very much.
08-05-2014 08:47 PM
It doesn't flash when we need it either. I've tried basically everything.
08-05-2014 10:12 PM
Do you have the manual? If not, I suggest you go to canon usa to download one for your camera.
Good luck.
08-06-2014 09:38 AM
"t doesn't flash when we need it either. I've tried basically everything."
Except cleaning the pin which tells the camera the flash is up.
