09-13-2022 01:37 PM - last edited on 09-14-2022 08:46 AM by Danny
Hello everyone,
let me preface this by saying that i am quite the novice when it comes to these cameras, and any help would be most appreciated.
I filmed a video the other day, and when i was looking through the display i noticed that it was foggy around the edges. when i downloaded the footage the white fog was still there. I don't believe any moisture could have gotten in so I'm not sure exactly whats going on here.
Does anyone know what I can do to fix my camera? Thank you in advance!
09-14-2022 07:01 AM - edited 09-14-2022 07:07 AM
That looks like some type of Creative Filter, to me. What shooting mode are you using on the top dial?
Do you know how to turn off Creative Filters? Resetting the camera back to factory defaults should clear it. You would first need to turn the top dial to “P”, and then look for the reset/restore option in the menus.
09-22-2022 12:44 PM
It is the creative filter mode, I have not seen this on any other camera:
09-13-2022 10:20 PM
It happens for both 😞
09-14-2022 07:05 AM
I don’t believe Creative Filters can be applied to video.
09-14-2022 07:48 AM
You might be right. Turning on video mode is just a matter of which direction you slide the Power switch. I have not used a Rebel in years. I think I recall my T5 would record video in whatever shooting mode was set on the top dial.
The darker area across the bottom of the sample image looks like a separate issue, a failing shutter.
09-14-2022 08:03 AM
I also believe it is a shutter problem. That's why I recommended the OP take a few additional steps.
09-14-2022 08:13 AM
This looks to be some sort of shutters problem.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT, 600EX II-RT
09-21-2022 11:00 PM
It did end up being a setting issue, or rather the nob on top of the camera. I truly appreciate all your help my friend, thank you so much!
09-21-2022 10:59 PM
It was a setting! Ifeel like a fool. I didnt even think to check. Thank you so so much!
09-22-2022 08:45 AM
What setting? We would like to know in case someone else comes here with the same issue.
09-22-2022 10:28 AM
The knob on the top was set to what looks like two overlapping circles, with one partially filled. Im not sure what setting that is. I must have accidentally turned it when i was moving my camera
