03-09-2020 09:29 PM
Hi!
I demo'd at a photo store the EOS RP, which feels just great in my hands. I demo'd using an adapter and my EF 24 F2.8 mm IS USM lens. One of my questions is:
Why did the photos come out with a blue tint (see photo - only change I made was to decrease the size)?
Color representation per image properties is sRGB.
I am hoping this would be an easy in-camera correction.
Thank you and all the best!
Annie
03-09-2020 10:33 PM
What was the white balance set to? Perhaps it was on say Tungsten (3200K)? For a bright sunny day, the color temp would be closer to 5500K. Lower values would add more and more blue.
If you captured the image in RAW, you can change the white balance in post easily. For example, in Adobe Lightroom, you could use the white balance eye-dropper tool and click on something that suppose to be white or gray. e.g. the snow. Or, manually adjust the color temperature slider.
03-09-2020 11:47 PM
Thank you!
I do not know what white balance was set to (I only demo'd it quickly and don't have it here) -- and it does not show up on my computer under image properties.
I appreciate the suggestions on editing in Lightroom! That sounds like a great tool! I will likely use Lightroom too once I upgrade my PC -- just using a freeware Photoshop now and haven't used its full functionality.
All the best to you!
Annie
03-10-2020 02:20 AM
@amatula15 wrote:Thank you!
Annie
Lightroom is nice to have, but not mandatory. The Canon DPP4 software can process RAW images, too. The biggest advantage to using Adobe LR is that it can perform lens correction on third party lenses.
03-10-2020 11:17 PM
03-11-2020 10:48 AM
Are you really using CS2? Did you really set the WB to manual?
I doubt CS2 will handle any new camera model correctly or at all.
03-12-2020 12:25 AM - edited 03-12-2020 12:28 AM
Hi Ebiggs,
You asked :"Are you really using CS2? Did you really set the WB to manual?"
What is CS2? I used a freeware version of Photoshop to decrease the size of the image so I could post here - but no other adjustments were made.
I demo'd the camera at a camera shop so have no idea of the settings. I wanted to see how it felt and shot, knowing the quick demo would not give me all I would love to know about the camera, but yet better than no demo -- or so I think sometimes! At other times, not knowing nor using the full capabilities and features of the camera makes it harder to make a decision after having demo'd.
I realize I have much to learn yet in DSLR photography. That factor makes it more difficult to review camera specs and make a decision based solely on those.
Thank you!
Annie
03-12-2020 10:39 AM
"...better than no demo -- or so I think sometimes! "
Not really! Can't be very good if it doesn't tell you or show you what the camera is capable of. It is actually worse than buying blindly if it shows a poor photo.
The EXIF data from your sample indicates CS2 which is a very old version of PS. Perhaps that is what the freeware version uses as a software. The WB indicated a setting of 'manual'. I don't understand that!
My thoughts is the adapter and lens are not the issue here and the settings on the camera is. I would ignore what you saw.
If you try again perhaps you might do a reset first. WHo knows what somebody else might have set?
03-12-2020 11:24 AM - edited 03-12-2020 01:14 PM
@amatula15 wrote:Hi Ebiggs,
If you're not familiar with shooting with a DSLR and working with RAW files this may blow your mind.
Are you aware of all the EXIF data that's attached to digital image files? It provides a ton of shooting and editing information that's very helpful when you're trying to troubleshoot why an image maybe doesn't come out the way you expected.
When posting images here, or on similar sites, it's best to leave the EXIF info attached if possible.
Here's the EXIF data (somewhat edited to save space) from the first image you posted.
IPTC
Record Version = 2
IPTC Core (Adobe XMP)
Expand All / Collapse All / Show/Hide XMP Source / Show/Hide XMP Legend
xpacket = begin="" id="W5M0MpCehiHzreSzNTczkc9d"
x:xmpmeta
xpacket = end="w"
EXIF IFD0
Camera Make {0x010F} = Canon
Camera Model {0x0110} = Canon EOS RP
Picture Orientation {0x0112} = normal (1)
X-Resolution {0x011A} = 720000/10000 ===> 72
Y-Resolution {0x011B} = 720000/10000 ===> 72
X/Y-Resolution Unit {0x0128} = inch (2)
Software / Firmware Version {0x0131} = Adobe Photoshop CS2 Windows
Last Modified Date/Time {0x0132} = 2020:03:09 19:27:18
Y/Cb/Cr Positioning (Subsampling) {0x0213} = co-sited / datum point (2)
EXIF Sub IFD
Exposure Time (1 / Shutter Speed) {0x829A} = 1/800 second ===> 0.00125 second
Lens F-Number / F-Stop {0x829D} = 10/1 ===> ƒ/10
Exposure Program {0x8822} = normal program (2)
ISO Speed Ratings {0x8827} = 320
Sensitivity Type {0x8830} = recommended exposure index (REI) (2)
Recommended Exposure Index {0x8832} = 320
EXIF Version {0x9000} = 0231
Original Date/Time {0x9003} = 2020:02:08 13:07:45
Digitization Date/Time {0x9004} = 2020:02:08 13:07:45
Unknown tag, Tagnum 0x9010 {0x9010} = data ===> -07:00
Unknown tag, Tagnum 0x9011 {0x9011} = data ===> -07:00
Unknown tag, Tagnum 0x9012 {0x9012} = data ===> -07:00
Components Configuration {0x9101} = 0x01,0x02,0x03,0x00 / YCbCr
Shutter Speed Value (APEX) {0x9201} = 630784/65536
Shutter Speed (Exposure Time) = 1/789.61 second
Aperture Value (APEX) {0x9202} = 434176/65536
Aperture = ƒ/9.93
Exposure Bias (EV) {0x9204} = 0/1 ===> 0
Metering Mode {0x9207} = pattern / multi-segment (5)
Flash {0x9209} = n/a (0)
Focal Length {0x920A} = 24/1 mm ===> 24 mm
User Comment (Hex) {0x9286} = 0x00,0x00,...
User Comment Character Code = not defined
Last Modified Subsecond Time {0x9290} = 48
Original Subsecond Time {0x9291} = 48
Digitized Subsecond Time {0x9292} = 48
FlashPix Version {0xA000} = 0100
Colour Space {0xA001} = sRGB (1)
Image Width {0xA002} = 2000 pixels
Image Height {0xA003} = 1331 pixels
Focal Plane X-Resolution {0xA20E} = 4160000/1415 ===> 2939.93
Focal Plane Y-Resolution {0xA20F} = 2768000/943 ===> 2935.31
Focal Plane X/Y-Resolution Unit {0xA210} = inch (2)
Custom Rendered {0xA401} = normal process (0)
Exposure Mode {0xA402} = auto exposure (0)
White Balance {0xA403} = manual (1)
Scene Capture Type {0xA406} = standard (0)
Camera Owner Name {0xA430} =
Body Serial Number {0xA431} = 052022002960
Lens Specification {0xA432} = 24-24mm F0-0
Lens Model {0xA434} = EF24mm f/2.8 IS USM
Lens Serial Number {0xA435} = 0000001baf
EXIF IFD1
Compression {0x0103} = JPEG compression (6)
X-Resolution {0x011A} = 72/1 ===> 72
Y-Resolution {0x011B} = 72/1 ===> 72
Embedded thumbnail image:
EXIF Interoperability IFD
Interoperability Index {0x0001} = R98
Interoperability Version {0x0002} = 0100
EXIF GPS IFD
GPS Version ID {0x00} = 0x02,0x03,0x00,0x00
According to this abridged info on ebiggs1's edited version of the same pic, he did his work in Photoshop CS6.
IPTC
Coded Character Set = 27, 37, 71
Record Version = 2
Date Created = 2020/02/08
Time Created = 13:07:45-07:00
x:xmpmeta
xpacket = end="w"
EXIF IFD0
Image Width {0x0100} = 2000 pixels
Image Length {0x0101} = 1331 pixels
Bits Per Sample {0x0102} = 8,8,8
Photometric Interpretation {0x0106} = RGB (2)
Samples Per Pixel {0x0115} = 3
Software / Firmware Version {0x0131} = Adobe Photoshop CS6 (Windows)
Last Modified Date/Time {0x0132} = 2020:03:10 08:49:02
(Reason For Edit: This post obvoiusly needed a bit more trimming)
03-12-2020 01:28 PM
