09-25-2024 04:25 PM - last edited on 09-25-2024 04:29 PM by Danny
Hey i realized that a lot of my RP photos arent as sharp as my M50 at further distances and a lot of times my RP photos are blurry and i never experienced the same with my M50.
https://drive.google.com/drive/folders/1ggc239v1EpPc3rZ9zn2lJ78--hZNbHOf?usp=sharing
The picture at the pier was with RF lenses and as you can see it cannot focus well at all. The other pictures are with a EF 50mm. The clarity of the walking person in with the m50 is just far higher than the people in the RP photo. Please take a look and see if you agree. (zooming in makes the biggest difference.)
09-27-2024 12:51 PM
I have had a look at the 10 CR3 images on the google drive folder. I have a couple of observations to add to the excellent points raised by my colleagues above.
From the images all that are with the EOS RP use Neutral picture style, the EOS M50 use auto picture style. This might account for two elements, the flat colours of the EOS RP images but also the sharpness difference. When set to Neutral style the sharpening is set to zero. A camera set to auto picture style chooses between standard, portrait and landscape, all three of these have sharpening set to more than 0. I found a sharpening value of 4 in each of the M50 files. Since I had the RAW images, I selected auto picture style for the EOS RP images and this improved the colour and the sharpness of all of them.
Next I noticed that the framing of two shots looked similar. M50 gas station.CR3 and RP gas station.CR3. When I checked the EOS RP was set to 1.6x crop mode, so then we are comparing a 6000 x 4000 pixel M50 image with a 3888 x 2592 pixel RP image. I'm not surprised to see a different level of detail in the two pictures.
I noticed that some shots are captured with high aperture values, mostly on the EOS RP, this can lead to diffraction loss and the EF 50mm f/1.8 STM is not at it's best when heavily stopped down.
My suggestion to more accurately compare the images is much the same as the others above.
Standardise the test images, use a tripod to mount the cameras. Set both to the same exposure, AF and Picture Style settings.
09-25-2024 07:39 PM
The problem here is that Full Frame cameras have shallower depth of field than their APS-C counterparts. Shooting at very wide open apertures on Full Frame will show this more. Shooting at F/2 for instance on APS-C camera will have more things in focus than shooting at F/2 on a Full Frame camera. Also the image sensor in an APS-C camera causes a 1.6x focal length increase. The lens will always be a 50mm lens but the angle of view changes depending on the sensor size. Note both of these pictures below were both taken with the EF 50mm F/1.8 STM lens. But one picture was taken on an APS-C camera the other was take with a Full Frame camera. The picture on the top was taken with the EOS 40D an APS-C camera. The picture on the bottom was taken with the EOS 5D Mark IV a Full Frame camera. Both pictures were taken at an aperture of F/1.8. Notice the picture on the bottom has more bokeh (background) then the one at the top.
09-25-2024 07:09 PM - edited 09-25-2024 07:12 PM
To expand on my last comment. While the R50 with a short FL lens is very light and may tolerate being used by looking at the LCD, the RP is much heavier and the potential for camera shake is magnified by the focal length. For that reason, conventional wisdom encourages you to use the electronic viewfinder instead of the LCD for composing and shooting. That is because you get three points of support: the two elbows tucked tight to the sides of the torso, and the camera pressed against the face - thus forming a sort of tripod. See this example of how to use a larger camera:
09-25-2024 07:19 PM
The OP has the EOS M50 not the EOS R50. So that camera is much smaller than the RP.
09-25-2024 07:54 PM - edited 09-25-2024 08:03 PM
Absolutely Demetrius - it is both smaller and lighter, and the lens configurations are lighter too.
To give you an idea of how important technique is, I will give the example of this image, taken with the Sigma 150-600c lens, hand-held, using the Canon EOS 5DIV, also a 30MP camera and with no IBIS.
This is the original image:
Using the EOS M5, essentially the same as your M50 but configured more for stills also hand-held, and using a slow shutter speed
09-25-2024 08:21 PM
Yes technique is very important and it will lead to very sharp pictures. Improper settings and techniques will lead to out of focus pictures.
09-25-2024 08:26 PM
Exactly my point, there is a lot more weight and leverage with a FF camera and a zoom on a telephoto setting compared to a fixed, light lens with short FL on a small, light body. The M50 was really designed for vloggers, so it lends itself to being used via the LCD as well as EVF.
09-25-2024 08:36 PM
The EOS M Series was really designed for content creators. So the lenses were small and compact to begin with. Generally you'll see more camera shake with telephoto lenses or a lens set to a telephoto setting such as 85mm. Most lenses in the telephoto range have IS to counteract camera shake. With newer cameras with IBIS will stabilize all lenses now. Instead of just relying on Optical Stabilization alone. Not all lenses have Optical Stabilization due to very wide open apertures such as F/1.2 or F/2.
09-26-2024 07:56 PM
I tried all of these with minimal shake and even on hard surfaces with a timer, 1 in 5 was actually sharp.
09-26-2024 06:22 AM - edited 09-26-2024 06:23 AM
I have been mulling this over and have not come to a conclusion.
One argument says that there is more of a tendency for camera shake with heavier cameras and lenses because your arms get tired and it's harder to hold your equipment still.
A counter argument says that there is more of a tendency for camera shake in lighter cameras and lenses because, due to its lighter weight, when you push the shutter button down down, it's easier to move the camera, and as Demetrius says, there is probably no IS in those short lenses at wide open apertures.
I've just been musing.
Steve Thomas
09-26-2024 01:54 PM
I think both arguments have in common is that the issue is technique in holding the camera with extended arms creating a far greater risk of camera movement.
