01-09-2024
05:45 PM
08:32 AM
I like to have C1 function as my default HDR shots. The manual is not clear how to do it. Please help.
01-09-2024 05:52 PM
For what camera?
01-09-2024 05:57 PM
Sorry. R8
01-09-2024 06:05 PM
Set up the camera the way you want it and select the Custom Settings Registration mode:
Then select the one you want to set:
01-09-2024 06:08 PM
Kv makes a very good point. It helps a lot to know what model we are dealing with. Looking at your previous posts, I would assume you are using the R8.
That said: generally speaking this is how I would do it. I am referring to the R8 Advanced User Guide, which is what you should be using.
Turn the Mode Dial to C1 (or C2),
Make whatever customizations you want to the camera.
In the 5th Page of the Wrench menu, select Custom Shooting Mode
In that page select to save settings to Custom mode
There are two options here. One is to have the mode update automatically while in that C mode, the other will not. Thus, if you make changes while in C1 (for example) they would not be automatically saved as the default for that mode and when you next use it, it will revert what was manually saved. If you choose automatic, it will save any new settings when you make changes.
This video may help:
01-09-2024 07:16 PM
Thank you for all the step by step guide.
However, it doesn't solve my issue. All I want is bracketing the exposures (2F stops under and over, thus 3 shots all together) and save it to C1`. Thus the next time I want to shoot HDR is simply set me selection to C1.
I hope I make myself clear
01-09-2024 07:24 PM - edited 01-09-2024 07:45 PM
To be honest, I'm a bit confused. Can you say specifically what is not working for you with the info you have received so far please?
I have found a video for assigning AEB to a custom button, I hope this is more helpful: while some of the menu selections might be different from your R8, they can be found in your Advanced User Guide as mentioned, still the principle is there.
How to Register AEB on EOS R as a Custom Mode - YouTube
Once C1 is recorded, and then recalled by dialing it, all of the settings will apply from condition of recording a C1 setting will be kept, but there is nothing to prevent one from changing any of them from that point for the specific instance of a shot. If you know you want to use AEB, then first switch to C1 first, then adjust your camera's other settings as you would normally do.
If that is not working for you, are you looking to assign the exposure bracketing feature alone to a button?
01-09-2024 07:55 PM
It's not that it doesn't work. Basically after I registered the setting, how can I input and save the settings, such as ISO, Shutter speed, Aperture?
01-09-2024 08:00 PM - edited 01-09-2024 08:02 PM
If you want to change the settings specifically for a particular shot, then go to C1 first, and autobracketing will be enabled, then you just change any other settings as you normally would.
If you want them to be automatically updated each time to that C1 function, in the menu for custom settings you select Auto Update. Then when you select C1 they will be the default settings, at which point you can change any of them as you would normally
If you want to preconfigure the settings like ISO, aperture and Ss, then apply them to the camera before saving to the C1 mode.
01-09-2024 08:02 PM - edited 01-09-2024 08:03 PM
@Eaglesnest wrote:Thank you for all the step by step guide.
Perfectly clear. However, I don't think HDR can be added to the custom control (C1 - C2). Admittedly, I don't have the R8, but it won't apply to the C settings on my R5, R6, or R6 II no matter how I attack it.
Newton
