EOS R7 locks up, chooses wrong exposure with Godox TT350c
ajm133
I seem to be struggling with using my r7 with Godox TT350c
     Using the camera In full auto mode (TTL on the flash, A+ on the camera)
     In very dim light- as in almost dark – there will be a brief pre-flash and then the camera locks up with an error E-70.  Need to turn off camera and sometimes take out battery to get it back to normal.  I know this is not a typical way to shoot but I tried it because I know my t3i would just focus as best it could then take a shot
     In low light, the camera will choose a very slow shutter speed and take a shot. I don’t see a pre-flash. My former t3i with Yongnuo flash would handle it with no issue and typically take a nice shot.
     The flash firmware is 1.7 which appears to be the latest version, and camera just pgarded to 1.4 (1.3.1 acted the same way)
     When shooting in Av and M mode it seems to act the same – essentially if there is not a lot of light the camera locks up.
10 REPLIES 10
Then the EL-100 fits your needs as you said that you use it in low light only. Since the EL-100 lacks on speedlite controls. I would recommend that you learn how to use the camera's in camera flash menu. Note in order to use the in camera flash menu. A Canon speedlite that supports it must powered up and in the hot shoe. All changes to settings must be done through the in camera flash menu. Setting flash sync will also be done in camera such as High Speed Sync (HSS / FP), 1st curtain / normal sync & Rear curtain/ 2nd curtain sync. The E-TTL metering pre-flash is visible with rear curtain sync which is normal. Rear curtain sync is used with long shutter speeds and it can only be used with shutter speeds slower than 1/30th on most cameras. So check your camera manual to see what shutter speeds it can be used with. The same applies to High Speed Sync (HSS/ FP) every came has a max sync speed. Most cameras are 1/200th or 1/250th but this varies between camera models. A more powerful flash would be needed for High Speed Sync (HSS/ FP). The speedlite would be discharged after a few shots since High Speed Sync (HSS/ FP) requires the flash to fire multiple times (pulse) during the exposure.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Friends and Family
