02-22-2026
10:39 AM
08:23 AM
A friend of mine was recently gifted a Canon R7 camera by her fiancé, to replace her old and tired Fujifilm camera. She has asked for some help from me on understanding a lot of the (new to her) menu since she knows I shoot Canon. I've been able to help her a lot on the different settings, but in one area I am looking for some suggestions here from the group.
Let me start here...
She loved the Fujifilm recipes, and was a little disappointed that Canon does not have these. I need to add that she does not love editing at all. I offered to teach her, but she said editing would take away from her love of photography - make it feel like a chore. She is asking me how she can learn to set up (adjust?) just a few JPEG picture profiles to look like some of the recipes she had before. Some of her favorites looked like film.
I know that Canon does NOT have the same custom options like Fujifilm does, and I explained that to her, so no need to tell me that. However a quick Google search gave me a billion (ok, only a million) options on how to go about setting a few of these up to kind of resemble Fujifilm recipes. I have never attempted anything like this, simply because I like editing RAW files. So... Instead of me sifting through a million (ok, in reality, only 100,000) videos and articles... has anyone here ever had any luck with setting up a few film like JPEG profiles on their Canon camera? If so, can you point me towards links of ones that actually look good (instead of the 99,990 that look mediocre)?
And just in case you are think of suggesting this, she does not want to trade in the R7 for a newer Fujifilm. She said her fiancé would be disappointed, and she really does love the camera and has been excited to learn more about it.
02-22-2026 01:02 PM
I have never used. but found this via search.
Canon Picture Style Editor is another tool.
https://global.canon/en/imaging/picturestyle/editor/
02-22-2026 02:01 PM
Gary,
The picture styles option mentioned by John is a good one. 👍 Hopefully that "works" for her.
DPP also supports recipes. With minimal work, she could create a her own recipie(s) and apply them to her images globally. Canon has superior color science. You can only encourage her. The rest depends on her.
02-22-2026 03:28 PM
https://cam.start.canon/en/C005/manual/html/UG-02_BasicShooting_0030.html
| Shooting Mode | |||
| Portrait | Close-up | ||
Group Photo | Food | |
| Landscape | Night Portrait | ||
| Panoramic shot | Handheld Night Scene | ||
| Sports | HDR Backlight Control | ||
| Kids | Silent shutter | ||
| Panning |
https://cam.start.canon/en/C005/manual/html/UG-02_BasicShooting_0170.html
You can shoot with filter effects applied. Filter effects can be previewed before you shoot.
Grainy B/W
Makes the image grainy and black and white. By adjusting the contrast, you can change the black-and-white effect.
Soft focus
Gives the image a soft look. By adjusting the blur, you can change the degree of softness.
Fish-eye effect
Gives the effect of a fish-eye lens. The image will have barrel distortion.
Depending on the level of this filter effect, the area trimmed along the periphery of the image changes. Also, because this filter effect magnifies the center of the image, the apparent resolution at the center may degrade depending on the number of recorded pixels, so set the filter effect while checking the resulting image. One AF point is used, fixed at the center.
Water painting effect
Makes the photo look like a watercolor painting with soft colors. By adjusting the effect, you can change the color density. Note that night scenes or dark scenes may not be rendered with a smooth gradation and may look irregular or have significant noise.
Toy Camera effect
Shifts colors to those typical of toy cameras and darkens the four corners of the image. Color tone options can be used to change the color cast.
Miniature effect
Creates a diorama effect.
Shooting under the default setting will keep the center looking sharp.
To move the area that looks sharp (the scene frame), see Adjusting the Miniature Effect. [1-point AF] is used as the AF area. Shooting with the AF point and scene frame aligned is recommended.
HDR art standard
Photos retain more detail in highlights and shadows. With reduced contrast and flatter gradation, the finish resembles a painting. The subject outlines will have bright (or dark) edges.
HDR art vivid
Colors are more saturated than with [
HDR art standard], and the low contrast and flat gradation resemble graphic art.
HDR art bold
The colors are the most saturated, making the subject pop out, and the picture looks like an oil painting.
HDR art embossed
The color saturation, brightness, contrast and gradation are decreased to make the picture look flat, so that the picture looks faded and old. The subject outlines will have intensely bright (or dark) edges.
https://cam.start.canon/en/C005/manual/html/UG-04_Shooting-1_0200.html
Just by selecting a preset Picture Style, you can obtain image characteristics effectively matching your photographic expression or the subject.
https://cam.start.canon/en/C005/manual/html/UG-04_Shooting-1_0210.html
You can customize any Picture Style by changing it from the default settings. For details on customizing [Monochrome], see
https://cam.start.canon/en/C005/manual/html/UG-04_Shooting-1_0220.html
You can select a base Picture Style such as [Portrait] or [Landscape], adjust it as desired, and register it under [User Def. 1] – [User Def. 3]. Useful when creating several Picture Styles with different settings.
Picture Styles that you have registered on the camera using EOS Utility (EOS software, ) can also be modified here.
02-22-2026 06:00 PM
John, Rick, and John... thanking all three of you for this great information. I'm going to forward these links and let my friend do some homework on the info before I give her a hand setting some of this up.
The only thing I think she will reject is the DPP4 suggestion because she is dead set on exporting JPEGs and calling them finished with no other effort. I tried talking her into some simple edit programs, and got the "You aren't listening to me" look. lol
02-22-2026 07:58 PM
So far as I know, it is possible to set the camera to save both JPG and CR3 files and then change the style in the camera menus and save a new JPG file. So, the same photo can have more than one version with different styles all in the camera.
06-08-2026 07:59 PM
Yeah, Picture style have a lot of latitude and once you set it up you can apply them across the board. very powerful if you get it right. If I was learning a new system I'm not sure I'd start with picture styles, at least when it comes to tweaking/fixing color. The easiest, of course, is set it once in DPP4 and copy the parts of the recipe that you like, across all your files. No need to mess with catalogs either.
06-09-2026 08:15 AM
Hard for us to let DPP4 and RAW go isn't it? @justadude LOL - we're not great at listening at taking people at face value sometimes. It is hard when our inner voice screams "no, no, you really DO want to take RAW and post -process like the rest of us!" But I can see where she's coming from. Zero post processing and 100% SOOC could be a sort of nirvana photography in a way, yes?
I really have no skills to offer here but find the idea fascinating and would ask that you apprise us of progress and let us know how things settle out. This would be extremely useful information the next time this topic comes around and someone wants to live in a 100% SOOC world.
06-09-2026 09:42 AM
I think that setting the camera to record raw as well as JPG and later applying more than one style in the camera to create more than one JPG from the same shutter press is still SOOC. The camera manual has examples.
Why should it matter whether the style to use in the camera is chosen before or after the shutter press? It is still in the camera.
06-09-2026 09:45 AM
She went with one of the picture styles packs that John suggested, did some minor tweaks, and is happy with them. Not sure why learning a new system would matter with picture styles. It's kind of like any of my other brand digital cameras... RAW files are a bit different to edit on the very first upload into LR or PS, but after an hour of playing around, it's just as easy as the other systems. I'm guessing it was just as easy for her when she mentioned she did a few minor tweaks and was happy. You probably missed the part where I mentioned she wants straight out of the camera... so no DPP4 for her. Her style is the jpeg on the card is the finished product, and she's good at it, so why change?
